Anyone feel free to chime in at any time. Lol. I'm kidding I know y'all stay busy answering dumb people questions like mine
Thanks Jay I also just went to my local Kawasaki dealer he said the same thing about the rubber crush drive but he said that it's more than likely sprocket and chain ware. Is this a possibility also? I did tell you this before but when I got the by the chain was very rusty so everdently they did not heat mine up on the chain.Put it up on a rear stand, engine off, in-gear, then grab the rear wheel and turn it forward and back to see if there's a lot of play. If so, the rubber "cushdrive" in the wheel is most likely worn and needs replacing.
If that's not it, the trans is the next possible cause (hopefully it's the drive).
You only want about 1 inch of chain slack when the bike is on the stand and make sure you sit on the bike with the kickstand not in use then put it on kickstand and check chainjameskeyes1981 said:Yup. Same as he told me. The chain and sprocket shows a little ware but no hook on the teeth. In gear with rear tire off the ground I have about 2 in. Of play back and fourth. This is normal correct? If so it must be the chain and sprockets because I tighten the chain up yesterday. It had bought the bike with about 3 inches of play in it but it is still doing the same clunking.
Awsome info. I appreciate the great advice. as for the play, I took my bike to get the front tire replaced and a friend of mine that I didn't know was a Kawi mechanic :facepalm: Told me there is NO cush drive left and that its metel on metal in there and recommended me to get one, so I have one on the way. Should be here wed. Any takers on how to change the cush drive? lolYou only want about 1 inch of chain slack when the bike is on the stand and make sure you sit on the bike with the kickstand not in use then put it on kickstand and check chain
Not difficult. Just remove the rear wheel and pull out the sprocket and carrier. The new rubber parts go in the wells on the wheel and the sprocket and carrier lugs drop in between them.Awsome info. I appreciate the great advice. as for the play, I took my bike to get the front tire replaced and a friend of mine that I didn't know was a Kawi mechanic :facepalm: Told me there is NO cush drive left and that its metel on metal in there and recommended me to get one, so I have one on the way. Should be here wed. Any takers on how to change the cush drive? lol
