1 ) Can someone give me a run down of what tools I will need? Links to pictures of kits that contain what I need, or detailed explanations of everything I will need would be best. I expect my HMF pipe to be arriving soon and I would like to do the work myself after it is installed.
2 ) On a completly different note, I have noticed that sometimes when I open the throttle way fast (imagine 'about' as fast as you could rev your engine to the 3-4 K RPM range) and sometimes it just.. hesitates.. it just does not rev at all. I do not know what this is called, sputtering, I suppose? Not too sure. If I roll on, even roll on a bit quickly but not a hard pull, it does fine.. it just seems to hiccup now and then and I am assuming this can be carb adjustments and cleaning more then anything? opinions?
