1 - 20 of 23 Posts
???Help! I am working on shimming my needles. I started with 2 #6 stainless steel washers, then went to one. Both times when I started my bike it ran like crap. It was OK for about 30 seconds then it was like it wasn't getting enough fuel. I noticed that there is a small hole in the bottom of the hard plastic piece beside where the needle sits. The circumfrence of the washer looks like it was blocking the hole. :mad:
I had a girl ask me to fax a document for her right after she gave them to me she ask me if I could make a copy of them for her... I look at her like...huh? .. I told her .. sweetheart you are getting the same documents back ... by been fax doesnt mean that they are going anywhere...she was shocked...and said really?? .... well duhhh!!
wow. shows you the kind of people in this world
95% just plain stupid
Discussion Starter · #14 ·
I haven't tried 2 yet, just statred w/ 3. I was wondering if there was a big difference. Reading on other forums and some say with two it's better but still a little flat. A couple said with three it's a tiny bit rich in the mid range. BTW it's still on the stand and it's getting late. So I'm going to finish tomorrow.
So the OD should be 5/16, right. So what should the ID be? I was looking at our bench stock for some washers and we have several diff sizes. And what about the thickness? I have saw several people saying use two, or three or maybe four?
Thanks R D. I got the 5/16 from the link posted from joeRWMN. I had our supply guy look up the specs from a stock number for a washer close to 5/16 that I found. The hole diameter is 0.125 inches, and OD 0.307 inches and thickness 0.016 inches. Aluminum alloy 2024 - Chromate coating. I know this is alot of numbers, can if someone could tell me if this is close.
1 - 20 of 23 Posts
