This past weekend, in-between celebrating my graduation from CU Boulder with a BA in Media Studies (Journalism), I decided to adjust my valve clearances. Coming up on 15,000 miles (I don't even know what the factory adjustment time period is), but hearing some valves clicking, it was time.
Feel free to chime in any time GummyBear, I know you've been planning on doing this for a while.
Here are the rules for this post:
1.) Please read everything. This is an INVOLVED maintenance procedure. We now have a PDF of the maintenance manual. There are many threads on here I will reference. I will not answer a question that has already been answered somewhere else. Keep in mind, it usually takes me 2 days to check back and catch up on all the traffic... there are much more detailed instructions in the manual. This is simply meant to give you a feel for how it will go.
http://www.newninja.com/general-tech/(carbureted-version)-ninja-250r-service-manual/
2.) IF you have advice, please share! This was my FIRST time undertaking a task of this nature, EVER. If you know of a way this would be easier, please let me know. Since it was my first, and my bike is still running, I feel confident that anyone who believes in their abilities, has patience, and the right tools, can do this.
3.) I reserve full rights to change/edit this post as I remember things, or errors are pointed out to me. I want to make it a clean, good, helpful post.
BASIC INFO:
TIME: 6 hours, this could probably decrease to about 2 hours the second time around
COST: $6.00/shim - shims needed (4), with my discount, and tax it came to about $26.
GLASSES OF JACK AND COKE CONSUMED: 3
So, let's get started, eh?
1.) Remove the fairings: http://www.newninja.com/how-to/removing-the-fairings-(plastic)/
2.) Drain the oil: http://www.newninja.com/general-tech/oil-change/30/
3.) Drain the coolant:
4.) This is what you're left with:
5.) Remove the spark coils, and the valve cover vent tube:
6.) Remove the valve cover. This is what you'll see, from a few different angles:
7.) Remove the crankshaft bolt cover
8.) Check to see if cylinder 2 is at TDC (TOP DEAD CENTER)
9.) THIS IS A CRUCIAL STEP!!!!! MEASURE THE VALVE CLEARANCES Measure the clearance between each valve lobe, and the "bucket" underneath it.
This is the table I came up with (all values are in millimeters -mm):
Known: Intake clearance range - .17-.24 Optimum (.195 ~ .20)
Exhaust clearance range - .22 - .29 Optimum (.255 ~.25)
Shims come from the factory in demoninations of .05 (EX: 2.75, 2.80, 2.85)
Measured:
Cylinder: 1 2
Valves: Intake Exhaust Intake Exhaust
Side: Left Right Left Right Left Right Left Right
Clearance: .17 .21 .28 .25 .21 .20 .23 .24
The ones in red are close to the boundaries, so I thought I'd adjust those.
BASIC INFO:
Measured:
Cylinder: 1 2
