Troubleshooting Guide
This is a simple trouble shooting list. It is meant simply as a rough guide to assist the troubleshooting for some of the more common problems.
Engine Doesn’t Start, Starting Difficulty:
Starter motor not rotating:
Starter lockout switch or neutral switch trouble
Starter motor trouble
Battery voltage low
Starter relays not contacting or operating
Starter button not contacting
Wiring open or shorted
Ignition switch trouble
Engine stop switch trouble
Main fuse blown
Starter motor rotating but engine doesn’t turn over:
Starter motor clutch trouble
Engine won’t turn over:
Valve seizure
Valve lifter seizure
Cylinder, piston seizure
Crankshaft seizure
Connecting rod small end seizure
Connecting rod big end seizure
Transmission gear or bearing seizure
Camshaft seizure
Starter idle gear seizure
No fuel flow:
No fuel in fuel tank
Fuel tap vacuum hose clogged
Fuel tank air vent obstructed
Fuel tap clogged
Fuel line clogged
Float valve clogged
Engine flooded:
Fuel level in carburetor float bowl too high
Float valve worn or stuck open
Starting technique faulty (When flooded, crank the engine with the throttle fully opened to allow more air to reach the engine.)
No spark; spark weak:
Battery voltage low
Spark plug dirty, broken, or maladjusted
Spark plug cap or high tension wiring trouble
Spark plug cap not in good contact
Spark plug incorrect
IC igniter trouble
Neutral, starter lockout, or sidestand switch trouble
Crankshaft sensor trouble
Ignition coil trouble
Ignition or engine stop switch shorted
Wiring shorted or open
Main fuse blown
Compression Low:
Spark plug loose
Cylinder head not sufficiently tightened down
No valve clearance
Cylinder, piston worn
Piston ring bad (worn, weak, broken, or sticking)
Piston ring/groove clearance excessive
Cylinder head gasket damaged
Cylinder head warped
Valve spring broken or weak
Valve not seating properly (valve bent, worn, or carbon accumulation on the seating surface)
Fuel/air mixture incorrect:
Pilot screw or idle adjusting screw maladjusted
Pilot jet or air bleed hole clogged
Air cleaner clogged, poorly sealed, element missing
Starter jet clogged
Poor Running at Low Speed:
Spark weak:
Battery voltage low
Spark plug cap shorted or not in good contact
IC igniter trouble
Pilot screw maladjusted
Pilot jet, or air passage clogged
Air bleed pipe bleed holes clogged
Pilot passage clogged
Air cleaner clogged, poorly sealed, or element missing
Choke plunger stuck open
Fuel level in carburetor float bowl too high or too low
Carburetor holder loose
Air cleaner duct loose
Compression low:
Spark plug loose
No valve clearance
Other:
IC igniter trouble
Carburetor not synchronizing
Vacuum piston doesn’t slide smoothly
Engine oil viscosity too high
Drive train trouble
Brake dragging
Poor Running or No Power at High Speed:
Firing incorrect:
IC igniter trouble (see IC Igniter (problem solved....for now))
Main jet clogged or wrong size
Jet needle or needle jet worn
Air jet clogged
Bleed holes of needle jet holder or needle jet clogged
Air cleaner clogged, poorly sealed, or missing
Air cleaner duct poorly sealed
Water or foreign matter in fuel
Fuel to carburetor insufficient
Fuel tap clogged
Fuel line clogged
Compression low:
Spark plug loose
No valve clearance
Valve not seating properly (valve bent, worn, or carbon accumulation on the seating surface.)
Knocking:
Carbon built up in combustion chamber
Fuel poor quality or incorrect
IC igniter trouble
Miscellaneous:
Throttle valve won’t fully open
Brake dragging
Clutch slipping
Overheating
Engine oil level too high
Drive train trouble
Overheating:
Firing incorrect:
IC Igniter trouble
Fuel level in carburetor float bowl too low
Air cleaner poorly sealed, or missing
Air cleaner clogged
Compression high:
Engine load faulty:
Clutch slipping
Drive train trouble
Brake dragging
Lubrication inadequate:
Engine oil level too low
Engine oil poor quality or incorrect
Coolant incorrect:
Coolant level too low
Coolant deteriorated
Cooling system component incorrect:
Radiator fin damaged
Thermostat trouble
Radiator cap trouble
Radiator fan switch trouble
Fan relay trouble
Fan motor broken
Fan blade damaged
Water pump not turning
Water pump impeller damaged
Over Cooling:
Thermostat trouble
Gauge incorrect:
Water temperature gauge broken
Water temperature sensor broken
Clutch Operation Faulty:
Clutch slipping:
Friction plate worn or warped
Steel plate worn or warped
Clutch inner cable trouble
No clutch lever play
Clutch spring broken or weak
Clutch release mechanism trouble
Clutch hub or housing unevenly worn
Clutch not disengaging properly:
Clutch plate warped or too rough
Clutch spring compression uneven
Engine oil deteriorated
Clutch housing frozen on drive shaft
Clutch hub spline damaged
Clutch friction plate installed wrong
Clutch lever play excessive
Clutch hub nut loose
Gear Shifting Faulty:
Doesn’t go into gear; shift pedal doesn’t return:
Shift fork bent or seized
Gear stuck on the shaft
Shift return spring weak or broken
Shift return spring pin loose
Pawl spring broken
Shift mechanism arm broken
Shift pawl broken
Jumps out of gear:
Shift fork EAR worn
Gear groove worn
Gear dogs and/or dog holes worn
Shift drum groove worn
Neutral positioning pin spring weak or broken
Shift fork guide pin worn
Drive shaft, output shaft, and/or gear splines worn
Overshifts:
Neutral positioning lever spring weak or broken
Pawl spring broken
Abnormal Engine Noise:
Knocking:
IC igniter trouble
Overheating
Piston slap:
Cylinder/piston clearance excessive
Connecting rod bent
Piston pin, piston pin hole worn
Valve noise:
Valve clearance incorrect
Camshaft bearing worn
Other noise:
Connecting rod small end clearance excessive
Connecting rod big end clearance excessive
Piston ring worn, broken, or stuck
Piston seizure, damage
Piston ring groove worn
Cylinder head gasket leaking
Exhaust pipe leaking at cylinder head connection
Crankshaft runout excessive
Engine mounts loose
Crankshaft bearing worn
Camshaft chain tensioner trouble
Camshaft chain, sprocket, guide worn
Alternator rotor loose
Primary gear worn or broken
Abnormal Drive Train Noise:
Clutch noise:
Weak or damaged damper
Clutch housing/friction plate clearance excessive
Clutch housing gear worn
Transmission noise:
Bearings worn
Transmission gears worn or chipped
Metal chips jammed in gear teeth
Engine oil insufficient
Drive line noise:
Drive chain adjusted improperly
Drive chain worn
Rear and/or engine sprocket worn
Chain lubrication insufficient
Rear wheel misaligned
Abnormal Frame Noise:
Front fork noise:
Oil insufficient or too thin
Spring weak or broken
Rear shock absorber noise:
Shock absorber damaged
Disc brake noise:
Pad installed incorrectly
Pad surface glazed
Disc warped
Caliper trouble
Other noise:
Bracket, nut, bolt, etc. not properly mounted or tightened
Oil Pressure Warning Light Goes On:
Engine oil pump damaged
Engine oil screen clogged
Engine oil viscosity too low
Crankshaft bearings worn
Oil pressure switch damaged
Wiring faulty
Relief valve stuck open
O-ring at the oil passage in the crankcase damaged
Engine oil filter clogged
Exhaust Smokes Excessively:
White smoke:
Piston oil ring worn
Cylinder worn
Valve oil seal damaged
Valve guide worn
Black smoke:
Air cleaner clogged
Main jet too large or fallen off
Brown smoke:
Main jet too small
Air cleaner poorly sealed or missing
Handling and/or Stability Unsatisfactory:
Handlebar hard to turn:
Cable routing incorrect
Hose routing incorrect
Wiring routing incorrect
Steering stem locknut too tight
Steering stem bearing damaged
Steering stem bearing lubrication inadequate
Steering stem bent
Tire air pressure too low
Handlebar shakes or excessively vibrates:
Tire worn
Swingarm pivot bearings worn
Rim warped, or tire not balanced
Wheel bearing worn
Handlebar clamp bolts loose
Steering stem head nut loose
Front/rear axle runout too large
Handlebar pulls to one side:
Frame bent
Wheel misalignment
Swingarm bent or twisted
Steering maladjusted
Front fork bent
Right and left front fork oil level uneven
Shock absorption unsatisfactory:
(Too hard)
Front fork oil excessive
Front fork oil viscosity too high
Rear shock absorber adjustment too hard
Tire air pressure too high
Front fork bent
(Too soft)
Front fork oil insufficient and/or leaking
Front fork oil viscosity too low
Front fork, rear shock absorber spring weak
Rear shock absorber oil leaking
Rear shock absorber adjustment too soft
Brake Doesn’t Hold:
Air in the brake line
Pad or disc worn
Brake fluid leakage
Disc warped
Contaminated pad
Brake fluid deteriorated
Primary or secondary cup damaged
Master cylinder scratched inside
Battery Trouble: (also see Motorcycle Battery & Battery Charging Tips)
Battery discharged:
Battery faulty (e.g., plates sulphated, shorted through sedimentation, electrolyte insufficient)
Battery cables making poor contact
Load excessive (e.g., bulb of excessive wattage)
Alternator trouble
Wiring faulty
Regulator/rectifier trouble
Battery overcharged:
Battery faulty
Other Miscellaneous
Sudden unexplained lose of power:
Out of gas
Snorkel clogged with Gummy Bears (seriously) See 8000 rpm and will not rev further
Bike riding erratically:
Crazy nut operating the throttle and clutch (just joking)
Battery voltage low
Main fuse blown
Valve seizure
Crankshaft seizure
Camshaft seizure
No fuel flow:
Fuel tap clogged
Fuel line clogged
Float valve clogged
Engine flooded:
Battery voltage low
IC igniter trouble
Main fuse blown
Compression Low:
Spark plug loose
No valve clearance
Starter jet clogged
Spark weak:
Battery voltage low
IC igniter trouble
Compression low:
Spark plug loose
No valve clearance
Other:
IC igniter trouble
Drive train trouble
Brake dragging
Firing incorrect:
Air jet clogged
Fuel tap clogged
Fuel line clogged
Compression low:
Spark plug loose
No valve clearance
Knocking:
IC igniter trouble
Miscellaneous:
Brake dragging
Clutch slipping
Overheating
Drive train trouble
Overheating:
Firing incorrect:
IC Igniter trouble
Air cleaner clogged
Compression high:
Engine load faulty:
Clutch slipping
Drive train trouble
Brake dragging
Coolant incorrect:
Thermostat trouble
Fan relay trouble
Fan motor broken
Fan blade damaged
Over Cooling:
Thermostat trouble
Gauge incorrect:
Clutch slipping:
Pawl spring broken
Shift pawl broken
Jumps out of gear:
Shift fork EAR worn
Gear groove worn
Overshifts:
Pawl spring broken
Knocking:
IC igniter trouble
Overheating
Piston slap:
Connecting rod bent
Valve noise:
Other noise:
Engine mounts loose
Clutch noise:
Transmission noise:
Bearings worn
Drive line noise:
Drive chain worn
Front fork noise:
Disc brake noise:
Pad surface glazed
Disc warped
Caliper trouble
Other noise:
Wiring faulty
White smoke:
Cylinder worn
Valve guide worn
Black smoke:
Air cleaner clogged
Brown smoke:
Main jet too small
Steering stem bent
Tire worn
Wheel bearing worn
Frame bent
Wheel misalignment
Front fork bent
(Too hard)
Front fork bent
(Too soft)
Brake Doesn’t Hold:
Pad or disc worn
Brake fluid leakage
Disc warped
Contaminated pad
Battery discharged:
Alternator trouble
Wiring faulty
Battery faulty
Other Miscellaneous
Out of gas
