There's not a big selection of tires for the 2007 and older Ninja 250, so theres not gonna be a big difference in width between tires.
The following is a list of what is available and some rider input on each.
Performance tires
Pirelli Sport Demon
Sizes: 130/90-16 rear; 100/90-16 front
One of the most popular tires for the EX 250 due to its good grip and handling. Good wet-weather performance, too. Run a search on the board for (many) opinions, and you too can join The Church of SportDemontology.
Bridgestone BT45
Always a favorite, due to its good handling and dual tread compound. The center treads on the rear tire are made from a harder rubber, while the sides are softer for cornering. Rain response is excellent.
Dunlop GT501
Sizes: 130/90-16 rear; 110/90-16 front (have to raise front fender to fit)
A popular choice for both speedy and distance riders, the GT501 is one of the few tires that can combine excellent grip with longevity. It has very good wet performance, and is the tire of choice for Ninja 250 racers (see below).
One of our long distance riders has run several sets of race take-offs, which means they've been used for a couple track days/races and then sold to a street rider. He has put a further 12,000 miles or more on each set (YMMV).
Since not everyone wants to raise the front fender to accommodate the larger size, it is common to run a different performance tire in the front (size 100/90-16). The GT501 rear/Metzeler Lasertec front combination is popular. Other choices would be BT45s or Sport Demons.
Dunlop GT501: The Racers' Choice, by Jim Race http://faq.ninja250.org/wiki/Dunlop_GT501:_The_Racers'_Choice,
Metzeler Lasertec
Metzeler has consolidated all of their performance bias-ply tires into this tire. It has a classic Metzeler tread pattern. They compare favorably to the GT501s for daily riding and wet performance; they are one of the best rain tires you can get, and the handling is very good, too. Of course, sticky tires usually don't get great mileage. At least three club members have gotten fewer than 7000 miles from the rear tire (YMMV). The fronts seem to be doing better.
Pirelli MT75
Sizes: 120/80-16 rear; 100/80-16 front
If you're looking for an inexpensive, sporty tire, this is a good one. MT75s have a rabid fan club on the board. Handling & grip are excellent, wet and dry. There's no real secret to the grip - they're soft as hell. Therefore, they don't tend to last as long as some tires (YMMV) but are very inexpensive: You can get 2 sets of MT75s for what a pair of Metz Lasertecs will run. If you're not averse to mounting your own tires, these are a very good option.
Recommended for the inseam-challenged as a way to get a slightly lower bike.
Avon AM63 Viper Stryke
This is one of the newer tires available. Our wear tester reports handling and wet performance under various conditions is excellent. Wear is good, especially considering the low price.
Speed ratings are "P" (continuous 93 mph).
Pirelli Diablo Scooter
Sizes: 130/80-16 rear; 100/80-16 front
A good budget performance choice. Sticky in aggressive mountain riding, stable in straight stretches, and confidence-inspiring in wet conditions. Tires track well and stay planted, and the price is right. As with most sticky budget tires, expect to change them on a regular basis, especially the rear.
Dunlop GT301
AUSTRALIA ONLY
A better tyre choice than stock. Good wet and dry grip reported by one of our members from Oz. We don't have a lot of information from club members, so ask local riders if you're interested in this replacement.
Touring/all-around tires
Kenda K671
A good value all-around tire. Recommended for commuters who occasionally do more sporty riding. Not a track tire, but unless you're insane they grip well on the street. They handle rain and heavy loads very well.
The only downside of the K671 is they are a little heavier than most of the other tire options. This makes the bike a little less flickable, but unless you ride on the edge of traction, you'll probably never notice. Other than that, they clearly perform and also last a good amount of miles. And they're quite inexpensive.
This tire is also called the Cruiser. Don't confuse it with the K673 Kruz. The Kruz is designed for Harley-esque bikes.
Metzeler ME 880
Sizes: 130/90-16 rear; no front
Important buying information
The most-recommended tire for loaded touring. Reports say it's good in the wet, too. However, there is often some serious cupping after 10,000+ miles. That takes some getting used to when riding aggressively. For someone who has only one set of tires, and who does varied riding, this could be a big deciding factor. This tire should really only be considered for serious touring.
The ME880s grip well in the rain and last a long time, but they are expensive. If you ride more than 10,000 miles per year, this is a good choice.
Avon Roadrider
Sizes: MT90-16 rear (130/90-16 with higher load rating, aka 'reinforced'); 100/90-16 front
These tires are being marketed as a general purpose tire. They are a good compromise between mileage and performance. They have good grip and are long-lasting. A good choice for 'sport commuting'. One N250RC rider rode across the country and back (8000 miles) and wore off only 2/32" of tread. They turn in slower than the stockers, but they can make deeper turns and the bike is more stable when turning.
Kenda K657
Sizes: 130/90-16 rear; 120/90-16 rear; no front
This is supposed to be the sportier of the Kendas, but it's a heavy 6-ply like the K671. It advertises a stiff casing and high-speed stability, so it's generally more suited to commuting or touring than aggressive riding. More confidence-inspiring when cornering, stopping and quickly accelerating than the stock K630, even in heavy rain. Compared to the MT75 it won't corner quite as aggressively, but should last longer. Mileage reports have been pretty good. It also soaks up bumps a little better, comfort-wise.
Since this tire doesn't come in a front size to fit our bike, you'd have to mount a tire from another manufacturer on the front.
Continental Conti Go
Sizes: 130/90V-16-Rear; 100/80-16-Front
High mileage and very good grip in all weather and road conditions, thanks to its modern tread compound. Improved carcass construction for easy handling and high stability
IRC Durotour RS-310
Sizes: 130/90H-16-Rear; 100/90H-16- Front
For general all around performance, handling and mileage, nothing beats a pair of RS-310s. H speed-rated up to 130 mph
Muscle bike/Sport touring tire. (Front Inflated Width/Measuring Rim Width: 4.10 in./2.15 in., Rear Inflated Width/Measuring Rim Width: 5.50 in./3.00 in. )
Cheap tires
Dunlop K630
Loudboys: I don't know what kind of situation the OE tires are designed for, but it sure isn't regular street riding. They don't handle predictably, they don't stick very well, and they don't last very long. The stock tires are fairly unforgiving compared to most of the good replacement options. Once they're unstuck they tend to stay that way.
Ian: Dunlop K630's are pieces of crap, and you're doing yourself a huge dis-service by riding on them.
Dunlop K330
We've had one member try these tires. He says they don't have the typical sportbike tread pattern, but are soft, sticky tires. K330's are original equipment for the Buell Blast, and guys on the Buell forums are generally changing them out for MT75s and Viper Strykes.
Pirelli MT66
This is basically a Harley tire. The tire life is good, but the tire has almost no wet traction, so it would be a poor choice for touring (even though it's labeled as a touring tire). It's made for long, straight, dry stretches of interstate. The cornering on dry roads is no better than the stock rear. Crawling to a stop at a light in the rain is annoying as well.
Cheng Shin tires
Cheng Shin tires are what you might call a 'value' line of tires. The thing is, they're not that much cheaper than a good set of MT75's (not cheap enough to justify their lack of grip, anyway). Don't skimp and get one of these; spend a little more and get a good tire.
Maxxis tires
This is the upmarket division of Cheng Shin. While Maxxis scooter tires are generally well-received, their motorcycle sizes have yet to make a big splash on our board. Very few members have had them. For the price, you can probably find an established brand that will do the job as well. If you see them, and the price seems good, you may want to give them a try. There is very little information to go on yet.
A couple member reviews of Maxxis tires:
M 6103: 130/90-16 rear only; Good in dry weather, but never felt comfortable in the rain.
V1 M6002: 130/90-16 rear; 100/90-16 front; Their high-end sport tire. If you spend a lot of time riding on the freeway where there is grooved pavement, stay away from this tire. The straight line center groove is hell to ride with.
Performance tires
Pirelli Sport Demon
Bridgestone BT45
Dunlop GT501
Metzeler Lasertec
Pirelli MT75
Dunlop GT301
AUSTRALIA ONLY
Kenda K671
Metzeler ME 880
Avon Roadrider
Kenda K657
IRC Durotour RS-310
Cheap tires
Dunlop K630
Dunlop K330
Pirelli MT66
Cheng Shin tires
Maxxis tires
