1 - 15 of 15 Posts
Can be a fairly involved process, But if you think you're getting screwed ask a male freind to get some quotes, see if that makes any difference
Haha I'm actually trying that out.
I'm just worried that once I get there and they see a chick, the quote is going out the window.
I got a really good quote for tires and mounting, but it was going to take them over a month to get the tires. I figured I really needed the tires so why wait. I kick myself now :-\
why the wait on the tyres?
CL, that's a little high, but not unreasonable. I usually go with what Joe mentioned, remove the wheel myself, ride the bus to the kawi shop, have them mount the new tire (I'm usually out the door for less than $125 - depending on what kind of tire I get), and then back on the bus to home... :p So that's $25 or less for mounting and balancing... Just be careful they don't mount the tire backwards...
That would be kinda stupid, it has an arrow right on the tire that tells you the direction to be mounted, mine do.
And the biggest part of the bill will be the taking off/putting back on of your tires to your bike. I haven't decided if I'm going to do it myself or let the shop do it for me with my new tires.
Max, I, and the shop guys know about the arrow, but if they're in a hurry, they've put my wheel on the tire machine the wrong way, and mounted the tire the "right" way, but since the wheel was upside down, it ended up being the wrong way.... I only warn about it because it's happened to me...
Discussion Starter · #9 ·
I ended up paying $70 to mount and balance my tires.
I was kinda bitter about it at first, but after seeing the poor guy struggle with the tires, I figured it was worth it.
1 - 15 of 15 Posts
