1 - 6 of 6 Posts
I am aware how much more tire matinence is on a motorcycle than a car, but how can I tell if the tires are good and how exactly do check the pressure? Will a bicycle pump suffice to increase pressure? Anything else I should know?
Get a digital tyre pressure reader and a decent pump ,make sure tyres aren't flat spotted or got nails Etc in !
Flat spotted? What does that mean exactly?Decent pump, like a bicycle pump?
OOOooo boy we got us a wild one here.....LOL
Flat spot is when looking at ur tire u will see in the Center instead of being rounded it will be flat across.....
U may have a lot of tred still on sides of tires.....
But the center may be close to the inner belts....
I bicycle pump will pump up a motorbike tire.....
U can also buy a small air compressor at a walmart, ect.
Campbell Hausfeld FP2028 1 Gallon Pancake Air Compressor - Walmart.com
I have this out in my bike garage to do my tires.....
Works great.....
I also have a 5 horse power in my cellar for bigger stuff...
Lokk for cuts in tires, nails, anything that shouldn't be there....
Front tires mite have some cupping....
Thats a sort half moon shape worn into the tire in places...
Also check chain/sprockets....
Sprocket shouldn't have completely pointed teeth....
Chain should not be rusty....
See how this sprocket has a bit of a square edge on the top of teeth...
Not pointed....
..... how can I tell if the tires are good and how exactly do check the pressure? Will a bicycle pump suffice to increase pressure? Anything else I should know?
Here is some good tire info.
Motorcycle Tire Wear
Tire Tips For The New Riding Season From Dunlop
http://www.newninja.com/forums/f97/trouble-finding-performance-tires-8343.html
Yes a bicycle pump will work if that is all you have, however if you are on the road and need to do a repair and need some air (which can happen a little more frequently depending on where you ride), you'll need a portable source of air in case of an emergency.
http://www.newninja.com/forums/f106/roadside-motorcycle-tire-repair-5475.html
1 - 6 of 6 Posts
