explain what this mod does and how it does it if you would please ^_^
and what is a bar
and what is a bar
This mod will increase the amount of air and fuel into the engine to be burned. More air and fuel, more power. According to Sportisi, this mod is being designed to make the 40hp mark for safe daily use for the 250 , and maybe around 48hp for 300. The bike will need to run on the highest pump octane.explain what this mod does and how it does it if you would please ^_^
and what is a bar
There we go....N not a wise crack in there.......:whistling::whistling:This mod will increase the amount of air and fuel into the engine to be burned. More air and fuel, more power. According to Sportisi, this mod is being designed to make the 40hp mark for safe daily use for the 250 , and maybe around 48hp for 300. The bike will need to run on the highest pump octane.
Bar is a unit of measure for pressure. 0.5 Bar = 7.2 psi
Blue ghost I just bought juice box and not happy with wat I've found was wondering if u would have a good map setup for full yoshimara system k&n flat filter with snorkel removed and juice box I can use either 95 or 98 octane fuel and yes I will be buying one of those turbo kits when available oh and it's a ninja 300 2013
Thanks for your help any ideas to get any more power gains for 300 and also when will turbo kit be available
There is not a HP gain for the 300. It's about 4-5 HP at the top of the rev range. The turbo system is not available yet. I'll post it up when I hear about it's availability.We're can I buy the turbo system
