Well, I did it. I got rid of the whole rear fender. Cutting it short just wasnt enough.
Heres a Photoshopped picture of what I wanted it to look like.
http://www.newninja.com/index.php?action=dlattach;topic=5.0;attach=288
But as my neighbor said, "It takes Balls!" Taking out screws is one thing, but making that first cut into a perfectly good wire is another.
I have pictures but the 'upload folder' is full, so if you want to see the final product drop me your e-m and I'll pass 'em along. In the mean time...
Heres what I put on
http://www.newninja.com/index.php?topic=357.msg4453#msg4453
It’s actually pretty straightforward. I pulled the license plate off, then cut the wires going to the plate light and the turn signals. I meant to buy a Dremmel to cut off the rear section but realized I hadn't done it after I started. I ended up using a razor blade... yes, the plastic is that soft. I put the plate where I thought it would be seen the best, marked the holes with an awl then made my first incision of this open heart surgery. I drilled out all four holes for the license plate then found out that when I drilled the lower left hole I actually pushed loose the flasher unit (at least that’s what I think it was). So, no bottom left bolt. The top two bolts are the LED's so I had to run the wires through first (and had to re-drill the holes a little larger). That was simple enough. Only problem I had was wire connectors… I didn’t have any. I was all out and ended up just twisting the wires together and wrapping them in electrical tape. I DO plan on getting some connectors this weekend and doing it right.
Then came the turn signals. :'( I had already lopped off the original signals so I was committed. I had to eye-ball the placement and mark with a grease pencil. Then I drilled the first hole into the beautiful blue plastic. Not only did I have to drill two mounting holes but I also had to drill a larger hole for the wires. If you look close you can see that I over tightened the left screw on the right signal. It cracked the plastic and now theres a gap… No touch, No touch! I’m not gonna mess with it, no tightening, no loosening, nothing! If it falls off - then I’ll fix it.
Throughout this project I did have the good sense to pull out the ole’ multimeters just to be sure I was putting power where it needed to be. And as you would expect (in my case at least) the ground wires and return wires were almost the same color and were solid, the “hot’ wires were striped.
After getting the first signal wired up, I gathered the courage to turn the key and hit the signal… IT WORKS!!! Well, if the first one was that easy I’ll just slap the last one together and “I’ll be darned, it works too! And on the first try!”
No directions, no experience, no help… Why was that so easy? I started at 1:30 in the afternoon and was done by 4:30 (of course no one was there to interrupt me).
Heres what I put on
