Krylon fusion gloss
Spray interior only
Use many light coats
Install...
Hope the little grommets stay in place lined up between instrument housing and front fairing.
If not, remove entire left fairing side cause you can't reach up there unless you are 12 and have chimp like arms. Loosen front assembly and tweek to the side to put grommet back in place. do this tweeking at your own risk. I never suggest tweeking.
If you are lucky install takes about 10 mins. If not , an hour.
I would like to thank TR who endured cussing and whining about the whole manufactruing process and how the designers are sadists. ( yes I get to use the new word) Sadists.
Here is mine with the painted and TR's DB ZeroGravity!
Spray interior only
Install...
