1 - 8 of 8 Posts
Be careful with Purple Power/SuperClean/Heavy Duty Degreasers etc. They will dull/streak paint and will darken raw aluminum if left on very long.
I haven't used Simple Green, but I'm pretty sure it's no where near as aggressive.
It depends on what you use it on. Simple Green is not as corrosive as Purple Power.
(Simple Green: 9.5 pH vs. Purple Power: 13.3 pH (source: MSDS))
Both should be diluted with water and rinsed well. If cleaning painted surfaces or plastic, I would use a car wash, light degreasing or oil cleaning I use hot water and Dawn.
I'm figuring on useing a car wash n wax cleaner on most the bike, but on that backend that's covered in chain lube all the time I need something stronger.
Specially that back rim....LOL
Think i'll go with the simple green, and even if i have to do it a couple times over i'll be safer...
I use Krud Kutter and very hot water when I get heavy lube stains, but for the most part I don't let the rims get that nasty. Keeping a good coat of polish or wax on the paint helps reduce the amount of build up.
See what my rims look like after 4 years and over 21,000+ miles.
Simple armor all car wash for me dry immediately. Then a coat of armor all ice bc you can put it on everything even your bubble. Let it haze and wipe it down. My wheels simple just a damp rag. Then dry with microfiber. I never let mine get kruddy enough to use any cleaner on it. I even put the ice on my exhaust u can use it in anything but glass
I own a detail shop, have been doing it for 25 years. For simple clean up, a damp micro fibre cloth will do then dry it with another. It takes bugs off really well, on helmet too. I try not to use too many chemicals , except wax, the more the better! If you use purple power , dilute at least half and half. If you stay on top of it , it only takes 15-20 mins.after each ride.
1 - 8 of 8 Posts
