1 - 5 of 5 Posts
Oil Filter List for the Ninja 300, 400, 500, 650, ZX-6R, ZZR600, ZX-10, ZX-14 & more
This is a list of oil filters that will replace the Kawasaki OEM Oil Filter for the Ninja 300. The Ninja 300 has a spin on type canister oil filter. It shares the same oil filter common on many other Kawasaki motorcycles. Always check the cross reference list along with product specifications available at the store or online if you have any questions about a filter. This may not be an exhaustive list, so feel free to update or add to it as necessary.
Kawasaki OEM: 16097-0004
OEM oil filter dimensions: 20 x 1.5mm threads, 14 psi by-pass valve, anti-drain back valve, 2.3" O.D. gasket, 2.5" height, 2.7" OD.
*note* (p/n# 16097-0004 supersedes 16097-0002, 16097-1061, 16097-1064, 16097-1068 as well as a few others, so filters that cross reference to these numbers may fit as well. Dimensions between filters may vary slightly.)
AC Delco: PF2135
AMSOIL: EAOM103
Carquest: 85358
FRAM: PH6017A
Honda: 15410-MCJ-000
K&N: KN-303
NAPA Gold: 1358
WIX: 51358
SuperTech: ST7317
Mobil 1: M1-110
Bosch: 3300
The following list of Automobile Filters should also fit the Ninja 300. They are about 3.25 inches long (compared to 2.5" stock filters):
AC Delco PF-2057
Auto Pro 2356
Autopride CF240AP
Baldwin B1402
Carquest 85356
Carquest Red B4620
Castrol 7317
Champion Labs Ph2867
Defense Filters Dl7317
Deutsch D-370
Federated Filters LF240F
Fram Extended Guard XG7317
Fram Extra Guard PH7317
Fram Tough Guard TG7317
Hastings LF240
Motorcraft Long Life FL-821
Napa FIL1356
Napa Gold 1356
Nippon G6Y0-14-302 A
Parts Plus PH2867
Pennzoil PZ-109
Penske 7317
Powerflo SL14610
Powerflo SL14620
Pro Gauge PGO-4620
Pro Tec 164
Promotive PH4610
Pronto PO3593A
Purolator L14610
Service Champ OF-4622
Shell SH48
Shell SH529
Valvoline VO50
Warner PH2867
Wix 51356
Got a list for the 2012 Ninja 650?
The Kawasaki OEM P/N for the 2012 Ninja 650 oil filter is 16097-0004, which is the same P/N for the Ninja 300, 400, 500, ZX-6R, ZZR600, ZX-10, ZX-14 and many others.
So this list should suffice for the above listed models.
1 - 5 of 5 Posts
