Maybe put some antifreeze in it?What can you do to keep your Motorcycle from overheating?
What conditions are you in when it is overheating?What can you do to keep your Motorcycle from overheating?
There's more than a dozen possible reasons as to why you are overheating and more than a dozen answers. Can you be a little more specific as to why the bike may be overheating?What can you do to keep your Motorcycle from overheating?
how do i make a thumb earl?Have a friend steel it n get rid of it n collect the insurance n go buy another....:thumb: Easy as that.....:dance:
exactly why the questions need to be asked!!we need specifics pplI guess we need to define "overheating". What are the symptoms? Is the temp gauge in the red? Is the fan running all the time? Just having the fan running doesn't mean it's "overheating" - it just means the coolant in the radiator has reached a set temp and there's not enough air flowing over the radiator to drop the coolant temp below the set point. If you are on the highway the fan won't run - there's enough air moving to draw the heat away, but if you are stopped the fan will move the air through the radiator instead. If the fan runs without shutting off - there's a problem. The fan should cycle on-and-off if you are sitting still or not moving much (heavy traffic) and are at the high range of the normal operating temp. If the gauge is in the high part of the normal range and the fan is cycling on-and-off when sitting I wouldn't say there's a problem. If the gauge is in the red zone and the fan is running all the time without turning off, or running when you are moving at a moderate speed or above, I would say there is.
Right.......exactly why the questions need to be asked!!we need specifics ppl
N pictures if possible....exactly why the questions need to be asked!!we need specifics ppl
what do you mean by overheating. Be specific. Bikes get hot in stop and go traffic and ive had bikes that got way to hotThanks all. You are right I should have been more specific. The bike was overheating in stop and go traffic. I checked the coolant levels and they are correct. I had the bike serviced at 600 miles and I am only at 800. So thanks again for some positive answers.
