um, basically you have 2 output shafts, one from each gear set, each with it's own clutch. The gears in each gear set look like this: 1,3,5 and 2,4,6. If you're familiar with how a manual transmission works you know that all the odd gears are located on one shaft, and all the even gears on another. Essentially what they're doing is turning the lay-shaft into an out-put shaft.
So, with all this talk of shafts done.... The end result is a quicker, smoother shifts. That's it. It still responds to power/torque the same way as any other transmission would. If you give the bike a hand-full of throttle and dump the clutch it will spin the rear-tire, and maybe wheelie uncontrollably. It's meant to smooth the shift point, so when you're cranked over, going balls out on the track and have to shift mid-corner, or while significantly leaned over the risk of breaking the rear tire loose is significantly less.
And this "mapping" of the tranny you speak of, I'm not sure I understand the question. The transmission is a force multiplier. So basically you map the fuel/air values for the engine, taking into account fuel efficiency, power, etc, etc, and then based on how much power you get, you program the transmission to shift at certain points. For instance, if the throttle is 1/4 open and opening but you're exhaust temp is too cold it means you're running rich and the bike will downshift to provide you with the accell you desire (hence the continually opening throttle), and to run faster to burn up the extra fuel in the system (hence the colder exhaust). It's a very inter-dependent system, looking at all different values to make it's decisions.
So I'm sorry, I must be stupid, but I still don't understand your question.
Do you mean how quickly does the tranny decide to shift? For instance, you're rolling in 6th gear and all of a sudden you need power to get out of the way, and you wack the throttle to WOT, will the bike jerk forward, or will it be smooth acceleration?
Well, I doubt this system will be in 6th gear at anything below 60-70mph, although you'd have to ask HOnda personally, and I think yes, if it were in 6th, it would jerk and chug chug for a bit while it shifted to a more appropriate gear and got you out of there. But I doubt the bike will ever put you in a situation like that. They're probably programming the shift points to be within a few RPM's of the power-band of the bike, so rolling down main street at 35mph the bike will probably be in 2nd or 3rd anyway, so you'll have that snap available. Unless you have it in the "fuel efficient/slow boat to china" setting, in which case you won't, but then you had it in the wrong setting to be doing such things with... Um, I hope that helps.
