Hi all,
Background to my current situation.
In Australia we have design rules that specify that bikes rear turn signals are required to be 300mm apart from each other.
I bought my bike off my cousin who installed an integrated LED tail light (which I now know is illegal). The integrated flashes as normal. I've also lowered my bike and a friend pointed out that a truck would have trouble seeing the signal from my integrated. I agreed so I went out and bought a pack of LED turn signals.
TEST RUN
I've only installed the right rear LED turn signal - so to test my wiring went like this:
Left front: Stock bulb
Left back: Integrated LED tail light
Right front: Stock bulb
Right back: LED
Switch bike on and try the signals.
Pressing LEFT: Signals flash as normal
Pressing RIGHT: Signals solid.
I've returned it back to normal for now while I try to figure out how to fix the right side first.
My question:
Since I'm intending to install only rear LED signals with stock front ones, should I be using resistors to slow down the flash? Is there any other alternative?
Thanks in advance for your input!
TEST RUN
Right back: LED
My question:
