The Kawasaki Ninja ZX-6R is a 600 cc class sport motorcycle built by the Japanese motocycle maker Kawasaki. It was introduced in 1995, and has been constantly updated throughout the years in response to new products from Honda, Suzuki, and Yamaha. The ZX series is what was known as the Ninja line of Kawasaki motorcycles in the 1980s and still carries the name today.
Specifications
Class Sport bike
Engine 636 cc (38.8 cu in) inline-4
Bore / stroke 67.0 mm × 45.1 mm (2.64 in × 1.78 in)
Compression ratio 12.9:1
Power 96.4 kW (129.3 hp) @ 13'500 rpm (claimed) 101 kW (135 hp) @ 13'500 rpm (with RAM)
Torque71 N·m (52 lbf·ft) @ 11'500 rpm (claimed)
Transmission6-speed
Suspension Front: 41mm inverted Showa BP-SFF fork with top-out springs
Rear: Bottom-link Uni-Trak® with gas-charged shock, top-out spring and pillow ball upper mount
Brakes Front: Dual 310mm petal rotors with dual radial-mount, Nissin four-piston, monobloc calipers
Rear: Single 220mm petal rotor with single-piston caliper
TiresFront: 120/70 ZR 17 Rear: 180/55 ZR 17
Rake, trail23.5° / 101 mm (4.0 in)
Wheelbase 1,394.46 mm (54.900 in)
Dimensions L 2,085 mm (82.1 in)W 705 mm (27.8 in)H 1,115 mm (43.9 in)
Seat height 830 mm (33 in)
Weight 192 kg (423 lb) (claimed) (dry)
Fuel capacity 17 L (3.7 imp gal; 4.5 US gal)
Fuel consumption 5.3 L/100 km (53 mpg-imp; 44 mpg-US)
