Are you sure the cable is free, and letting the throttle return completely? With the engine off, you could open the throttle to different positions and watch that the throttles are hitting the stops at the carbs when you release it.
Or you might have a vacuum leak. If the idle mixture screw don't do anything, the carbs may have deposits inside.
If you're not already, try using Ethanol-free gas - it might help by richening the mixture slightly (over E10) if it's lean. I'd also add 1 oz per gal of a fuel system cleaner like Techron Concentrate or Seafoam to the fresh Ethanol-free gas.
