1 - 20 of 35 Posts
Okay, I have a 2012 ninja 250r, and I LOVE it with everything I have- in fact, its the only thing I have. Well I took it for a ride the other day and had a little fun on it, I enjoyed the ride y'know. Well when I stopped and turned it back on to roll it in my house, it started just fine. Now the problem is when I kicked down to first, it automatically shuts off- like i Hit the kill switch. Kickstand was up, and has been. So I took off the sensor to replace later, thinking it was a sensor malfunction, but even after the sensors off, it still kills when I kick down to first. I have no idea what to do or even what to check. So I'm hoping you guys can help me.
Is your bike cold?
I know I'm probably wrong here, but is your idle good? My bike does the same when I put it in first when the idle is too low.
Turn ur idle up. On the left side if your bike there is a little black "dial" turn the dial will raise your idle and that might help. Mine is a little less than 2.5
To add on, unless his 250 differs from my 500 greatly, it should run perfectly around 1500 RPM.
Discussion Starter · #9 ·
nope, not yet...but its next on my list! just as soon as i change my filter and oil when i get off work. ill keep yall updated as i go! thanks, btw. such a helpful community, i love it.
I noticed that too, helped me get my bike back on the road after my fuel lines gave out from being so old.
Fast, Free Video Hosting & Video Sharing - VideoBam
theres the video, click play at the bottom of the screen. Idk how to imbed videos, but there you have it. I tied the two wires together for the kickstand safety switch that were leadin up to it, and still...nothing.
Filmed with a HD toaster.. lol
Seriously though, did the sound cut out mid wat or was it just me?
Discussion Starter · #20 ·
yeah my phone sucks, But I just went through some of the stuff I did...standard procedure for starting and wanting to get going, then BAM. It shuts off...clutch held in As soon as I kick down. I make it go by just popping the clutch up at a higher rpm as soon as I shift down, obviously bike jumps and pulls off. so I'm stumped.
1 - 20 of 35 Posts
