Will add some more photos of the finished product soon. Sorry, don't have any pics from install of undertail kit up yet, but I will say it was a bitch!
Hotbodies undertail kit requires you to replace the existing turn signal relay with an electronic on, but doesn't tell you that and also doesn't include one. Otherwise when you turn on your turn signals they just stay on and don't blink.
maybe you should change the flasher for ur LED turn signal..I had a similar situation when I fitted my intergraded tail light, my turn signals also stayed on, and never "blinked" as well.
but having the tail piece off allowed me to hear that the rely wasn't working.
the problem was this, when you fit L.E.D. lights on to the 250, you lower the wattage in the current.
so there isn't a strong enough current to activate the relay, the L.E.D has less resistance than the stock bulb.
easy fix for me was to put two in line resistors just before the light and have them share the same earth, screwed to the frame.
that allowed enough wattage to engage the stock relay...:thumb:
