1 - 16 of 16 Posts
(My Grammer sucks so excuse any miss types or other inperfections) First of all i would like to give Credit to hellvetica For pointing me to this Slip on! Now that i got that out of the way, install for the slip on total time to install it took maybe 20min, you will need two people tho to do this unless you have a stand for your bike because you do have to push hard and the bike will move unless someone is holding it. As for the after affect the sound is amazing its has a deep idle sound and gets higher on trottle. IF your looking to NOT stand out this is not one for you like Hellvetica said this is a loud muff. It looks Great and sound great...as for the preformace it could be just in my head but i did feel a great deal of diffrence especialy in the mid range.... but with all this said i took a be4 and after vid that i will post later (btw is there away to put vid up or can i just past link) Thanks ....comments welcome
Nice choice isn't it? What color did you end up getting. My green matches my bike PERFECTLY!!! And i took that stainless steal heat shield and i had a friend of mine powdercoat it black so the metal doesn't stand out as much. Next you need to shim the needles. You wont notice it now but later you will notice you have to rev it up to get the bike to pull like it should. No worries it takes about 3 hours to do it and most of the time is taking off body pannels. I used 2 #4 washers.
http://www.facebook.com/album.php?aid=2026164&id=1175310042&l=b76ef96e42
Discussion Starter · #11 ·
Thanks! And yes it is the black and crome with the ero end cap. Prob the only down side to this pipe is ur looking at 2 weeks to get it.... Is there a walk trw on how to shim the needles my dealer said all I might have to do is drill out the plastic covering the carb ajustment and jus ajust it.
That is the color that I'm going to get..I guess it takes 2 weeks b/c they custom make their exhausts to order.
If you will search carb shims Red Rider has done a great write up on it.
1 - 16 of 16 Posts
