1 - 4 of 4 Posts
does anyone know the trick to connecting the carb to the air filter box? the rubber fittings that come out of the box to the carb dont line up, they are a tiny bit higher than the mouth on the carbs. i tried installing the carb side first and then the box and vice versa with no luck. it seems like there should be an eay way to do this
i read that unscrewing the bolts under that battery will free the air filter box enough to do this but mine just moves about a 1/4 inch which does nothing. i cant find anything about lowering it to line up with the carbs
i dont know what to do : ( somebody help....
1 - 4 of 4 Posts
