I have the new ninja 300 and want more speed out of the 115 max I've heard it go up to. How do I increase it with my sprockets? Is it more teeth or less?
For more top end speed increase the front or decrease the rear. And I believe 1 tooth on the front is about the same as 2-3 on the rearmikeaninja300 said:I have the new ninja 300 and want more speed out of the 115 max I've heard it go up to. How do I increase it with my sprockets? Is it more teeth or less?
It doesn't seem worth it to be honest .theyre designed to go that fast for a reason and more top end you might be putting additional and unneeded stress on the engine !if you want faster top end get a bigger bike designed to do it ,indyjoe7 said:Is it worth the trouble? Does it off set the computer or anything else.
Just wondering.
Ya I figured that, I just bought this for a short time to break in and teach my wife on till its paid off to buy a bigger bike. I was jut trying to squeeze something more out of itmorgan46 said:It doesn't seem worth it to be honest .theyre designed to go that fast for a reason and more top end you might be putting additional and unneeded stress on the engine !if you want faster top end get a bigger bike designed to do it ,
Is it worth it?Is it worth the trouble? Does it off set the computer or anything else.
Just wondering.
But gearing up mite make it better ( Lower RPM ) at highway speeds?It doesn't seem worth it to be honest .theyre designed to go that fast for a reason and more top end you might be putting additional and unneeded stress on the engine !if you want faster top end get a bigger bike designed to do it ,
And mess the bottom end up !earlthepearl said:But gearing up mite make it better ( Lower RPM ) at highway speeds?
:thumb::thumb:.......
If you want more than 115 get a bigger bike.
Splat.....
I'm guessing the bottom end is to low geared anyway.And mess the bottom end up !
I've gone 1down on the front of mineearlthepearl said:I'm guessing the bottom end is to low geared anyway.
I know my 650 sure is n when it's time for a sprocket/chain change out I am going 1 tooth diff on the front.
:dance::dance::dance:
.... more top end you might be putting additional and unneeded stress on the engine !
The Ninja 250 nor the Ninja 300 were designed with top speed in mind. The were designed with ease of drivability and economy in mind. Needless to say neither one is endowed with front end lifting torque, unfortunately they are really under geared in stock form. The Ninja 250 is more than capable of utilizing a 15 tooth front sprocket effectively without a loss in torque or HP. In fact the bike's first gear becomes much more useable and the overall reduction in rpm speed is much less stressful on the engine while maintaining maximum mpg.And mess the bottom end up !
Just gives better pull out of corners and yer I do trackdaysearlthepearl said:But.... U probly wanted a faster take off at start n the next couple gears? Maybe u run track.
Myself.... I just go for nice scenic rides, and play a little on the mountain twisties.
No track
:thumb::thumb::thumb::thumb::thumb:Just gives better pull out of corners and yer I do trackdays
