I thought the information on this website was very interesting and educational. Much of the information many might have read or already know. However, as with any subject/topic dealing with different gasoline and additives, many will have their own experiences, opinions and expertise. Hopefully others will find it useful.
Simple E10 precautions are usually enough to avoid most gas-caused problems.
#1 E10 Gas Problem=Water Absorption Causing Phase Separation:
No miracle additive exists that can stop ethanol from absorbing water ---> Your best defense= Buying high quality gasoline + replacing often - Always test gasoline to confirm water-free with 10% or less ethanol.
Note: Sta-bil Fuel Stabilizer and Star Tron Fuel Treatment are currently listed as the two safest products with E10 gas, when a gas additive is necessary. They're alcohol-free.
You can review a list of gasoline additives at http://www.fuel-testers.com/is_gas_a..._e10_list.html
TIPS to help Choose a Gas Additive with E10 fuel :
- AVOID products that contain alcohol (includes isopropyl, methanol, etc.) and/or strong solvents, emulsifiers and water-absorbing agents.
- No additive (chemical ingredient) can prevent or remove water from a sedentary tank in storage.
- Don't fall prey to deceptive advertising and scare tactics - Check product ingredients before use.
- Additives that are beneficial usually raise energy (improve performance) and help protect parts (lubricate).
- Since E10 is a strong solvent, cleanser, de-greaser, anti-freeze and octane enhancer it often replaces the need for additional gas additives. Ask yourself, why add more alcohol, for "prevention" for ethanol alcohol-caused gas problems? Simply makes no sense...
