You may be confused about which color to choose for your HID conversion kit. The color of the output is determined by the temperature. The lower the temperature (usually around 4300k or so) is the whitest and brightest. As you increase the temperature the color changes into more exotic colors but decrease their lumen output.
At 6000k you have a light blue, 8000k a deeper blue, 10,000k an starts to turn blue/purple, 12000k starts to turn to purple. I recommend anything between 4300k-8000k to look the best but also be extremely bright.
4300K Pure White
4300K has an approximately 3200lm output, which is more than 3x the light output of the traditional halogen light and is the color temperature with the most output. The light appears fairly white, and has light yellowish hue when reflected off the road identical to the OEM HID equipped vehicles. This color is for customers who are looking for pure performance while improving the looks of their headlights. It is ideal for customers who does a lot of back road or canyon driving and need the optimal visibility.
6000K Diamond White
6000K has an approximately 2800lm output, which is 3x the light output of the traditional halogen light and slightly less light output compared to the 5000K. Although it has a bit lesser light output, it emits pure white light with very slight and barely noticeable tint of blue and purple.
8000K Iceberg Blue
8000K has an approximately 2550lm output, which is about 3x the light output of the traditional halogen light and slightly less light output compared to the 6000K. While it has a bit lesser light output, it emits a more blue lighting than the 6000K
10000K Brilliant Blue
10000K has an approximately 2200lm output, which is more than 2x the light output of the traditional halogen light. 10000K produces a deep blue light output approaching violet and the blue is noticeably deeper than the 8000K.
12000K Exotic Violet/Purple
12000K has an approximately 2100lm output, which is more than 2x the light output of the traditional halogen light. This color temperature puts out a deep bluish violet light and is deeper colored than the 10000K. It is for a customer who is looking for the most extreme and most exotic looking light output.
4300K Pure White
6000K Diamond White
8000K Iceberg Blue
