TekkaBlade said:
Top speed is electronically limited to 160 km/h.
It's not quiete like that.The RPM is.At 13500 RPM the rev limiter kicks in.When the needle touches the red line in 6th gear at 13000 RPM and it does,the speed indicated is 180km/hr.
darkhorse said:
A question for the FI people . Has anyone with a fuel injected 250 ninja tried an aftermarket exhaust? Just curious about getting the mixture tuned .
Yes,I do run AreaP.With 24 sensors burried everywhere there are no chances the engine is out of tune.
No rich no lean run.No hot no cold start problem.The ECU compensate every needs instantly.
Is the FI bike really faster than the carbed bike?
In std form,with more horse power and taller final drive,it must be.
Just put that pipe on and forget it.No programming needed.
