Front sprocket Nut
2258 Views 5 Replies 2 Participants Last post by  earlthepearl
Anyone know what size the Front sprocket nut is on a 2012 Ninja 650 sport is?
I don't have one that size n will need to buy one for the sprocket/chain change-out coming up.
I have a 1/2" impact n breaker bar, but not the socket.
:facepalm: :facepalm:
1 - 6 of 6 Posts
Not 100% sure, but I will check my workshop manual, it shouldn't be too different between our two models
I've been finding on other forums it should be a 27mm...?
ok, I'll see what it is once I get home from work. It should be the same, but I will confirm it for you.
You wouldn't believe it, but the service manual does not tell you what size the nut is!
Right......
I was on a bunch of other forums n on there it says 27mm....??
Guess i'll just buy a 27mm n try it...
I can always bring it back...
1 - 6 of 6 Posts
