1 - 3 of 3 Posts
Can anyone help me out and explain the proper way to bleed the brakes on an 06 zx6r? I've been searching the internet all night/morning for a NEW front master cylinder and can't find anything but used ones and rebuild kits and I do not want to rebuild it, anyone know where I might be able to find that?
· Moderator
okay so the best thing I can tell you about bleeding your breaks is this go your local auto parts store and get a break break it should cost about 299 and will make things a lot easier. Start at the top move your way to the bottom making sure that as you pull the lever you open the bleeder and before it is completely compressed you close the bleeder. When you are done you should not be able to fully pull the lever for your brake. Also do not get brake fluid on anything. And use dot 4 or dot 5. Not dot 3!!!!
1 - 3 of 3 Posts
