....I have spark and fuel. Need to check compression.
I've been told timing on bikes this almost never give issues. It'll crank. It just won't ignite. It ran fine then just started this so I don't think it's flooding
Your bike is over 20 years old, anything can happen. Just because you have spark and fuel does not necessarily mean the timing is on point or the compression is up to snuff. IC Ignitors can go bad without warning.
You really haven't given much detail about the bike. What do you mean by ..
"started acting up"?
What kind of mods do you have?
Do you have pods or an airbox?
Has the bike sat out in the rain?
Does the bike have fresh fuel?
What else have you checked?
Have you looked at the pilot jets again to double check they are not blocked again with some other debris?
Will the bike even sputter with choke?
