Guest
·Sometimes when I shift from 1st to 2nd I slip into neutral by mistake, engine revs cause I hit the throttle and I go nowhere. Of course I then have to shift back to 1st and try it again. Oops, false neutral.
My question is, can you adjust the space between the gear shift and your boot so you can pull up on the shifter in a shorter distance OR adjust the gear shifter so it doesn't take as far to pull up before it clicks into the next gear?
