1 - 18 of 18 Posts
Hi guys (and gals)
I'm new to modern bikes and I recently bought a zx6r p8f, and this might be a dumb question but on the exhaust at the bottom of the bike, near the belly but on top of the pipe are two devices with wires going to them. What are these?
I heard somewhere they pre heat the exhaust or the catalytic converter. Is that true and if so what purpose does that have?
Thanks
I think that valve system is further back under the tail before the silencer above the wheel but these are just after the down pipes combine near the front. If I can figure out how to post a picture I will.
Those are o2 sensors in the exhaust not sure why there are two but that's what they are
That for if ur not running ur bike hard enough.....
It heats ur exhaust so it don't carbon up....
Hahahahahahahahahaha....
:facepalm: :facepalm: :facepalm: :facepalm:
Has a filament like ur toaster....:whistling:
Hi guys (and gals)
Thanks
Where abouts in the uk are you,and yep they are O2 sensors they send a signal to the ecu etc and help with the running of the bike
1 - 18 of 18 Posts
