Sounds like an electrical issue. Possibly bad / disconnected rectifier and dead/weak battery. A non working or bad rectifier would not properly charge the battery. A dead/weak battery will make the relay make a clicking noise.
Thanks Blue Ghost,Sounds like an electrical issue. Possibly bad / disconnected rectifier and dead/weak battery. A non working or bad rectifier would not properly charge the battery. A dead/weak battery will make the relay make a clicking noise.
Thanks Jay,^ Good point.
I wasn't thinking along those lines, but that makes sense if the clicking noise isn't coming directly from the engine. I was thinking that a rocker may have fallen off or something like that, but a dead battery that doesn't have enough power to fully engage the starter motor would do what he described.
When you say "the engine won't start" do you mean it turns over freely/quickly but doesn't light up or it doesn't want to turn over? Where is the clicking coming from?
I didn't noticed much except the exhaust sound different -- thought that was because of valve clerance was done.Wow, that's a lot of damage. How did the bike run for those 15 minutes you rode it?
