Running the Dynojet stage 2, gutted exaust, "36$" muffler mod and a bigger sproket.
After you do that good stuff if your around 1000 feet above sea level stick with the 98 jets and use the recomended needle settings. Do the 3 turns out on the mixture screws and you should be set.
I ran a 102 after a 108 wouldn't pull above 10k, I was way to rich. Changed the 102's out for a 98 and readjusted the mixture screws and it pulls the front wheel up in 2nd gear and gets to 55 in second. Huge improvement.
Specs\mods
16th front sprocket
Dynojet kit stage 2
RedRider's 36$ muffler
Snorkles cut
So far top speed is 103.
Pulls the front tire up in second using Racer X's 'Slap shift technique' Dont let off the throttle and just slap the clutch while hitting it home, Great technique for pulling away from people as it allows near constant acceleration.
If you have any problems with your jet kit let me know and I'll help you out, I get on here every few weeks but now that I've posted this I will check back frequently.
Keep the site alive RED!
Specs\mods
16th front sprocket
Dynojet kit stage 2
Snorkles cut
