Huh? Today, I ran my bike out of gas. Like had to call a friend to come and get me out of gas. I first got under the bike and turned the thing to "pri". It started, and went about 100 yards. So I stuck it back on "on" and went and got gas. Maybe you just had a once in a blue moon experience, or your bike is special. Not sure, but the bike definately does NOT have a reserve. Oh well. hahaninjadad said:I could agree with that if the setting was on "pri". The last time I got mine back from the shop it was on "pri" instead of on. But, that was my experience. Your mileage may vary......![]()
yep this is correct fuel flows unrestricted past the daiphram. no vacuum from the engine is needed to draw fuel.Doomsday said:The other thing I understood was when the tank is set to "pri" or prime, it's for draining the remainder of gas from the tank for servicing/removing the tank.
Yup!Jester said:Awesome thats good to know. I would suspect this happens only on carborated bikes though...
Your welcome. HA. JK. Thanks to all!ARMYMEDWORRIOR said:wow i never realized how much cleaner this forum looks compared to that link on bottom of page one of this post....glad im a member on this one..
By opening the throttle it actually allows more air flow into the carbs and that's why you get spark. Just be ready to let off the throttle when she turns over!Doomsday said:Another interesting thing to know is if you ever drop your bike and it won't start, this is what you should do. Rev the throttle while pushing the ignition, this burns off the extra gas that flooded the engine. I read it in the manual and it's a good thing I did cause a laid my bike down the first time I ever rode it, and it worked. I leaned it over too far and just had to lay it down easy in the grass, no damage, just got dirt on the blinker and mirror. And I saw a guy lay his ninja down at speed while braking to stop for traffic at an intersection after hitting an oil slick on a wet road, same thing happened to him, bike wouldn't start. Laying the bike down floods it I guess.
