I did an oil change successfully once. This time everything went wrong. The oil sprayed all over from the filter cap on the test ride. What did I do wrong?
I took off drain plug and dumped oil. Tightened screw with new washer.
Then I took off oil filter cap, dumped oil and put new filter on. I did not change any rubber o-rings. Sealed it up again. Everything was hand tight, nice and snug.
Filled crankcase up with oil. Turned it on. Let oil fill filter area. Then re-fill crankcase based on sight.
Went for test boot and pow the oil starts spraying everywhere. (BTW There was still lots of oil in crank and filter cap)
To make things worse, I started all over again. This time I tightened the filter cap with my giant torque wrench and pow the cap split in three pieces.
What did I do wrong???
