I thought I would start a thread about doing engine mods that are a little more complex than just buying parts and bolting things together. The bolt on stuff is the basis for modifications but there is a limit .
What got my inside my engine? I was trying to do some cam tuning with adjustable sprockets. Before I started I found I had very low compression ON #1 cylinder. I pulled the head and found the valves where leaking . I pulled the valves and found they where just not seating . I fixed that by lapping the valves and they seat now without any leakage .
But I have the engine Half torn down so I was thinking .What can I do .
I want to add pistons with Higher compression . But they have to be ordered and You have to buy 4 at a time so 500 dollars and 6-8 weeks is a winter thing
I want to do some modest head porting I don't have a flow bench . but I have some experence with this.
The other thing I was thinking was to deck the cylinder block.
The base gasket is .010 thousands thick . I took it out and checked for piston to head and piston to valve interference . It clears without a problem .
Since this is a street engine I wont do cams and carbs . So I don't want to up the compression to much .
i was think of having a machine shop mill .010 thousands of an inch off the top of the block then reassemble it with a new base and head gasket .
Any thought ?
Any thought ?
