TERRAMOSTRO
Starting from! $16590Engine
º Type L twin cylinder, 2 valve per cylinder Desmodromic, air cooled
º Displacement 695 cc
º Bore x Stroke 88 x 57.2 mm
º Compression Ratio 10.5:1
º Power 53.7 kW - 73 HP @ 8500 rpm
º Torque 61 Nm - 6,2 Kgm @ 6750 rpm
º Fuel injection Marelli electronic fuel injection, 45 mm throttle body
º Exhaust 2 into 1US Forest Service Approved Spark Arrestor
º Transmission Gearbox 6-speed
º Ratio 1st 32/13, 2nd 30/18, 3rd 28/21, 4th 26/23, 5th 22/22, 6th 24/26
º Final drive Chain
º Clutch APTC wet multiplate with hydraulic control
Chassis
º Frame — Tubular steel trellis frame
º Wheelbase — 60.5 inches
º Rake — 26°
º Front suspension — conventional cartridge fully adjustable
º Front wheel travel — 8.12 inches
º Front Wheel — 21 inch
º Rear wheel travel — 8.12 inches
º Rear wheel — 18 inch
º Front brake — Brembo 300 mm disc, 2-piston caliper
º Rear brake — Brembo 245 mm disc, 2-piston caliper
º Fuel tank capacity — 14 l (of which 3 l reserve) / 3.6 US gal (of which 0.8 US gal reserve)
º Estimated fuel mileage — 50 mpg
º Weight — 395 lbs
