KAWASAKI NINJA 250R 08-10 Custom Levers - Sport bike Racing Parts-Performance Sportbike Custom Levers,Rear sets,Sport bike Accessories
$62 for adjustable levers on the 250!
Well, it's been a while since I last posted anything about these levers from the2wheel, that's because they are still working great. However, I did order a new set. This time they are silver and the quality is still there. This time when I ordered them, they were $34.55 ($6 cheaper than when I first reviewed them). This order came with instructions and each lever in it's own little bag and the hardware looks improved from the first set. The only small complaint I have is that one of the black levers started to fade, which is common with anodized metals. Other than that, these adjustable levers are amazing.The finish is awesome. Having seen similar more expensive levers, I really can't tell a difference. These levers are very solid pieces of aluminum. Not cast alloy metal machined to look like aluminum. These levers are much thicker and a slight bit heavier than the OEM levers, but not enough to make a substantial weight gain. They fit just like the OEM Levers with very close tolerances and also the necessary slack where needed. The standard length levers appear to be a tiny bit longer that the OEM levers. With these levers installed I do not have to squeeze as much with the ends of my fingers. My hands are more closed and the levers sit closer to the base of my knuckles. I have the levers both set on the # 3 setting. The brake lever operates the brake light in all 6 settings. Shifts seem to be quicker, smoother and easier with the lever closer to the grips. It is definitely easier to grab a handful of brake right after installing the brake lever. The adjusters ratchet nicely and stay in place. Overall, operating the controls is much much better all around. The levers also flex backwards about 1/4 inch. A worthwhile purchase for now. I'll see how they hold up over the long haul.
Got these ones off ebay. the2wheels
