I had smoke coming from my odometer area, unmounted it and found it was coming from the wiring harness to the headlights and the High beam indicator was permanently on. The wire was exposed slightly and I guess melting the plastic.
I'm going to fix the wire, but also want to change the bulb. I can't remove the wiring harness from the actual bulb. I managed to move the rubber piece and unclip the bulb to have it out, but now I have it in a more easily accessible spot and still can't separate the two. So it's Wiring harness/rubber/headlight all still attached.
I ride an 02 Ninja 500R. The only video on changing a bulb I found was on a new model so I don't know if it appears differently or if there is some clip holding the bulb to the wiring harness I need to undo. (I undid the clip holding the actual bulb into the bike). I've pulled pretty hard and don't want to break anything.
