Guest
·i have just recently changed my oil and had it up right and the oil doesnt show up in the site glass....im guess i put about 1 1/2 quarts in the crankcase what can cuase this to happen ??? ??? ??? ???
Ok that makes sense!spooph said:D, it's the difference between a dry and a wet fill... Technically, the Little ninja doesn't have an oil tank. All the oil is housed in the crank case. For a wet fill, as in, no oil filter removal, and therefor not all the oil drained out, it's 1.9. But I think in the manual it says for a dry fill it's 2.1 or 2.3q of oil... Which is why I go by the window, because unless you take the whole engine apart, and squeegy every last molecule of oil off/out, measuring the oil and pouring it in is just not accurate enough. But putting in oil, running the bike for a while (to let the oil filter get soaked), and then adding oil as needed is "most best" IMO, cause you can get it to the exact same level every time!
