1 - 1 of 1 Posts
Area P Dyno Charts
Below are our dyno graphs from our initial R&D tuning sessions. We have created 7 base maps to work with initially and will continue to refine & perfect them, creating an even larger data base. In addition, as previously indicated, our partner in the FI Micro Programmer (Fuelmoto), will be getting one our production systems and creating even more maps under their perfect conditions. These maps will also include airbox delete (K&N Filter Pod). Under Fuelmoto's expert tuning hands, we believe the performance numbers will yield even better numbers.
We hope to have additional information up on our website within the next week, to include pricing, part numbers and additional technical data. We also have additional "bolt-on" performance parts undergoing R&D for the 300 as well.
Run #3 - Baseline stock run OEM exhaust. Run #28 - OEM exhaust with FI Micro Programmer, Snorkel removed, K&N Filter Panel direct replacement.
Run # 3 - Baseline stock run OEM exhaust. Run #80 - Area P Ultra High Mount System, Fi Micro Programmer, Snorkel removed, K&N Filter Panel direct replacement.
Run # 3 - Baseline stock run OEM exhaust. Run #56 - Area P Standard Mount System, Standard Muffler. FI Micro Programmer, Snorkel removed, K&N Filter Panel direct replacement. Run #80 -Area P Ultra High Mount System, Fi Micro Programmer, Snorkel removed, K&N Filter Panel direct replacement.
Run # 3 - Baseline stock run OEM exhaust. Run #56 - Area P Standard Mount System, Standard Muffler. FI Micro Programmer, Snorkel removed. K&N Filter Panel direct replacement. Run #80 -Area P Ultra High Mount System, Fi Micro Programmer, Snorkel removed, K&N Filter Panel direct replacement. Run #90 - Area P Standard System, Long Quiet Muffler, FI Micro Programmer, Snorkel removed, K&N Filter Panel direct replacement. As you can note, all versions of the Area P systems, with proper mapping, have very similiar performance characteristics. Especially noting that the Standard System with Long Quiet Muffler being very quiet as compared, yet offers excellent performance.
Run #3 - Baseline stock run OEM exhaust. Run #28 - OEM exhaust with FI Micro Programmer, Snorkel removed, K&N Filter Panel direct replacement. Run #40 - Slip-On prototype.
This last graph we included only to illustrate the reason why we will not be offering a Slip-On. We can get within .3 hp (yes, 3/10th) as much performance from our FI Micro Programmer (at peak) and the OEM muffler, as with a Slip-On (and our Micro Programmer). We gave it every oppertunity, including many different design versions. And further, without the FI Programmer, we struggled to get a Slip-On to perform as good as stock! A Slip-On is reasonably easy to design & manufacture. So believe me, if a Slip-On offered more performance than what we have noted (and remember that's with our FI Micro Programmer as well), we would be offering one. So just like we found on the 250R, a significant "performance" increase just isn't there with a Slip-On.
1 - 1 of 1 Posts
