1 - 3 of 3 Posts
Hey guys. I just traded a 72 Honda xl 250 for a 96 zx7r. Wow, it has no fairings and won't start. I'm replacing one of the ignition coils. Is there a way to find out which coil is #1$4 and which is #2&3? One has a green wire connected and the other red. Thanks
erm, are the old plugs/wires still plugged into the engine and wired to the coils? Couldn't you just trace them? Usually the wires are also of a specific length, so they only fit in there one way particular way... Concerning green and red wire, I don't know. On the 250 the green wire is on the cylinder 1 side, but there are only 2 cylinders so it could go either way to infer for your bike.
All of the wires are the same length and there are not any markings specifying which is which. The only difference is wired that connect to the coils on the opposite side from the plug wired coming off. I wish the solution was as simple as you suggested. Thanks for tryin
1 - 3 of 3 Posts
