Kawasaki issued a service bulletin affecting all Ninja300, 300/abs models. MC 13-02....
On eligible units, the vehicle may stall under decel due to an improper setting of the ECU. Could cause potential for a crash.
The letter sent to customers includes DO NOT RIDE UNIT UNTIL REPAIRED. If YOU replaced the ECU previous to the letter to correct a problem related to this, you may be partially/fully reimbursed.
NOTE: IF YOU HAVE A BLUE DOT NEXT TO THE PART NUMBER ON THE ECU, IT INDICATES A REPROGRAMMED ECU.
