1 - 1 of 1 Posts
2008 Versys Specifications
Engine Type: Four-stroke, liquid cooled, DOHC, four-valve per cylinder, parallel twin
Displacement: 649 cc
Bore & Stroke: 83.0 x 60.0 mm
Compression Ratio: 10.6:1
Maximum Torque: 44.9 lb/ft @6,800 rpm
Cooling: Liquid
Fuel Injection: Digital fuel injection with two 38mm Keihin throttle bodies
Ignition Digital: CDI
Transmission: 6-Speed
Final Drive: O-Ring Chain
Frame: Semi-double cradle, high-tensile steel
Rake/Trail: 25°/4.3 in.
Front Tire Size: 120/70-17
Rear Tire Size: 160/60-17
Wheelbase: 55.7
Front Suspension / wheel travel: 41mm hydraulic telescopic fork with adjustable rebound and preload / 5.9 in.
Rear Suspension / wheel travel: Single offset laydown shock with adjustable rebound and spring preload / 5.7 in.
Front Brake: Type Dual 300mm petal discs with two-piston caliper
Rear Brake: Type Single 220mm petal disc with single-piston caliper
Fuel Tank Capacity: 5.0 gal.
Seat Height: 33.1
Dry Weight: 399 lbs.
Overall length: 83.7 in.
Overall width: 33.1 in.
Overall height: 51.8 in.
Color: Passion Red
Warranty: 12 months
Good Times™ Protection Plan: 12, 24, 36 or 48 months
* Model not available in California
Source: Kawasaki (www.kawasaki.com)
1 - 1 of 1 Posts
