1 - 9 of 9 Posts
I know this has been beaten to death...With that said, I wasnt able to get a simple direct answer without the arguement of why mess up the bike..
So this is the deal, I recently bought a house and was blessed by the previous owner with a free Kawasaki Ninja 250R in mint condition! Im not really a Bike guy but i do have a license and have owned a Ducati 748, cbr600rr. This little bike is pretty quick, agile, nice looking, close to nothing to insure, 75mpg, and has a sports feel.
The bike currently has a 130mm tire in the rear (stock). I have a brand new Dunlop Q2 160/60/17 tire that is just sitting in the garage (again, left for me by the previous owner). The 130 tire makes the bike look horrible and almost unwanted. I dont mind riding the bike but i have to do something with the rear tire. Naturally, the free $175 dollar tire sitting in my garage is a nice surprise!
My question or questions are...
Will this fit without modification?
What effect will the larger tire have other then aesthetics?
Will the stock rim accommodate such a large tire?
If I do have to modify the swing-arm, How drastic will the mod be? shaving/extending?
If i want to outright swap the swing arm with its bigger counterparts, What Swap takes the least modification to put a larger tire and rim? (Possibly a 180 or 190)
Just a disclaimer, I can buy a 600cc but dont want to do that when i have a free bike now.
So the presumption that i should get a bigger bike is out the window. Thanks in advanced
Simple direct answers:
NO
The flickability will decrease slightly
NO
Significant - widening, new spacers, and slightly lengthening it.
Other than Eric's conversion kit for 160 tires, you're on your own here.
There are no significant performance increases to be found on the street from running a bigger tire in the rear. So essentially, it's just a cosmetic mod, and a pricey one to do and maintain at that (bigger tires are much more expensive than 250-sized rubber). If you don't want people knowing you ride a 250, then take the cash you're gonna spend on modifying it, and throw it in with the cash from selling the bike, and buy something bigger.... I know you said that wasn't an option, but you're looking for different answers to a topic which has been beaten to death - as you said yourself... Not sure what you're after here... It's just not worth it...
But if you still want to do it, look up a guy named "Eric" on the board here, and he can get you a kit to convert your 250 to a 160 rear.
to answer your question (post #1)
-Yes, they do fit, but the shape of rear tyre are no different than donut & you won't be able to remove those 1" chicken strip (what a waste)
- refer to answer on the first question
- Yes, 160/60/17 do fit on stock rim, but the shape are much rounded as stock rim width are not designed for that size
- no modification require
- I don't have answer for this one
as for additional, there's aftermarket wheel for ninja which is fit for the 160/60/17 tire size and no modification require. another option, there's forumer in here who modify ninja650 rear wheel to fit on ninja 250r with modification. I myself using aftermarket wheel for ninja 250r with 4.5" width size which is fit up to 160/60/17 tire size without any modification, as in the picture below
compiration between 160 on aftermarket wheel vs 130 on stock wheel
2
I will be able to remove those little chicket strip left on my rear tire once i put some extender on my rear set, or just get aftermarket rear set
1 - 9 of 9 Posts
