like 25 horsepower.
Engine:
Four-stroke, liquid-cooled, DOHC, parallel twin
Displacement:
249cc
Bore x stroke:
62.0 x 41.2mm
Compression ratio:
11.6:1
Cooling:
Liquid
Carburetion:
Keihin CVK30 x 2
Ignition:
TCBI with digital advance
Transmission:
Six-speed
Final drive:
O-ring chain
Frame:
Semi-double cradle, high-tensile steel
Wheelbase:
55.1 in.
Rake / trail:
26 degrees / 3.2 in.
Front suspension / wheel travel:
37mm hydraulic telescopic fork / 4.7 in.
Rear suspension / wheel travel:
Bottom-link Uni-Trak® with 5-way adjustable preload / 5.1 in.
Front tire:
110/70-17
Rear tire:
130/70-17
Front brake:
Single 290mm hydraulic petal disc with two-piston caliper
Rear brake:
Single 220mm petal disc with two-piston caliper
Overall length:
82.1 in.
Overall width:
28.1 in.
Overall height:
43.7 in.
Seat height:
30.5 in.
Curb weight:
374.9 lbs.
Fuel capacity:
4.8 gal.
Color choices / special edition:
Candy Lime Green, Metallic Spark Black, Passion Red/Metallic Spark Black
MSRP standard / special edition:
$4,199 / $4,449
Warranty:
12 months
Optional Good Times™ Protection Plan
12, 24, 36 or 48 months
